MF 135 oil pan hole.
Chris
05-30-2004 14:29:43
I bought a MF 135 with a hole is the left side of the oil pan, it is a perkins gas.The owner told me something fly of the engine internally. What should I expect?
thebigron
05-31-2004 19:20:38
 Re: MF 135 oil pan hole. in reply to Chris, 05-30-2004 14:29:43
Believe it or not a person out of Canada just tried to bid an oil pan off on e-bay last week, opening bid was $1.00 Canadian. Closing bid was $1.00. Not bad if it was your particular Perkins engine. Might want to contact fellow would have been a good deal just to pay shipping. The item number to pull up follows> Good luck 3806797036
bstrucker
05-31-2004 13:55:17
I'm guessing this thing doesn't run.Usually a hole in the oil pan means that a connecting rod broke in the engine and knocked a hole in the pan.It depends on how many other things the rod hit until the engine stopped.If you lucky it will just need a rod a probably a piston.At worst it could need a complete engine.hope you got it cheap.
