parts for changing from a canister to spin-on filt
Big Dean
05-31-2004 13:51:29
I was going through some old notes about 3 or 4 years ago & I found these part numbers for the parts to change the Continental G176 Z134 & Z145 gas engines canister type filters over to a spin on these numbers go to [1] a metal plate [2] a gasket [3] a threaded adapter with a set of threads on each end of it [4] the filter it's self. I don't know which number goes with which part I don't know why I did not have that but the numbers are 1051 113m1-- 1051 114m1-- 1051 115m1-and 1069 954m91
The adapter has a nut made in the center of it that has threads on each end of the nut. One end screws in to the block it runs though the metal plate and gasket. With threads on the other end for the spin-on filter. The filter gasket seals against the metal plate. I have sent these to a few people that said they got the parts & thet worked. the last time I sent them to some one was over a years ago so you might check with a dealer to see if these parts are still available
Rick Cook
05-31-2004 21:23:12
 Re: parts for changing from a canister to spin-on in reply to Big Dean, 05-31-2004 13:51:29
Hi Dean,
Glad to see you back online!
I was wondering if the 152 Perkins (3cyl diesel) also had adapters for spin on oil filters?
Big Dean
05-31-2004 21:46:11
 Re: Re: parts for changing from a canister to spin in reply to Rick Cook, 05-31-2004 21:23:12
You can get the filter head for the spin-on filter right here on this site you just unbolt the old head & bolt on the spin-on filter hear in it's place
