12 Volt Conversion on TO30
W Schubert
05-05-1999 12:39:10
I would like to convert my TO30 to 12 volt. Has anyone done this? What parts need to be replace and what can stay?
Thanks in advance.
CHUCK@OHIO
06-11-2003 02:36:59
 Re: 12 Volt Conversion on TO30 in reply to W Schubert, 05-05-1999 12:39:10
TUNE YOUR TRACTOR UP AND HAVE A GOOD 6V BATTERY WITH 585 COLD CRANKING AMPS AND IT WILL BE BETTER THAN PUTING 12V IN IT. I GET MY BATTERYS AT TSC (TRACTOR SUPPLY). IF YOU PUT 12V IN IT, IT WILL TAKE THE RESALE DOWN ALSO BECAUSE IT IS NOT ORGINAL. IF YOU STILL THINK YOU HAVE TO CHANGE TO 12V, WHICH YOU DON'T, ALL YOU HAVE TO DO IS PUT IT IN. DO NOT USE YOUR LIGHTS, IT WILL BURN THEM OUT. IT WILL BURN YOUR POINTS OUT MUCH QUICKER WITH 12V ALSO. GOOD LUCK AND DO NOT CHANGE.
