MF 245
chief 83
06-29-2004 19:57:07
After working my tractor, so far just cutting raking and baling I have a pretty significant oil leak out the weep hole in the (what I'll call) the bell housing. After sitting for a while the leak stops and there's barely a drip. Is this the rear main leaking? If so is it something that's fairly easy to change? I'll be in there addressing some clutch issues this winter and will attempt a repair then. Thanks for any tips.
Big Dean
06-29-2004 20:38:38
 Re: MF 245 in reply to chief 83, 06-29-2004 19:57:07
If it is engine oil you probably have a rear pan gasket leaking that is very common on the AD3-152 engines after they get some age on the. The 1/4" cork gasket gets hard & Shanks up starting to leak. If you head the tractor up a steep grade the oil will usually run out the weep hole. It is very rare the crankshaft seals leak on those engines. If I can be of further help email me.
