Value of a 1951 Massey Harris
Challen
07-07-2004 13:32:45
I have a 1951 Massey Harris tractor.I just bought some land and it was left.I was trying to find out what it's value is if any.So if anyone has any infomation please let me know.Thank you.
Alberta Mike
07-08-2004 05:20:11
 Re: Value of a 1951 Massey Harris in reply to Challen, 07-07-2004 13:32:45
Go to the top of the transmission/differential casting case. On the upper machined surface there are two plates bolted down to the case. One is a cast shifting platform (forward), the other is a steel cover plate (back). Between these two plates is a space. Go to the left side of the machined surface space (between the two plates) and look for the serial number which will be stamped into that area. It will roughly be about where the clutch pedal sits when at rest. Post the serial number here and we'll ID the model and year. It will be hard to find so do some wire-brushing and scraping.
Challen
07-07-2004 17:29:50
I am not sure on that.It has a tricyle frontend.I looked at the Massey Harris place and found a picture that looks like the tractor I have.It looks like one of the first ones they made.I can send you some pic's scents I can not tell you alot about the tractor.
Jim - Illnois
07-07-2004 14:12:43
What model is it? The 1951 Massey-Harris tractors have different value.
