t 20 drive train fluid
Big Dave
07-08-2004 02:36:04
Does the transmission on the t 20 use hydraulic fluid or transmission fluid. And what kind~~
Thanks
marlowe
07-08-2004 17:39:22
 Re: t 20 drive train fluid in reply to Big Dave, 07-08-2004 02:36:04
the trans and hyd. all use the same oil 90 wt. mineral oil NOT 90wt. gear oil massey no. is M1103 and don't let dealer tell you they don't have it they do or use GL-1 NOT GL-5 from walmart or napa but you will find it at rural stores only not the city ones
Jeff-oh
07-08-2004 06:54:31
The answer to your question is Yes and NO.
The TO-20 and TE-20 have a combined Transmission and hydraulic system.
No: you use neither a transmission fluid nor a Hydraulic fluid.
Yes: you use a combined Trand.-Hyrdo fluid. Specificly use 90wt GL-1 spec. Mineral Oil. 80wt below 50 deg.
This oil is available in 5 gal. jugs in several places. Rural Wal-mart's, TSC, NAPA etc.
Also, check out Big Dean's site as he has an article there about oils.
Jeff
