massey harris 22 wheels
charlie
07-12-2004 07:06:04
i have a massey harris 22 with 28" rear wheels. were there different sizes for these? i would like to get a taller wheel on there if possible. i was hoping for 32". thanks for the help.
Alberta Mike
07-12-2004 09:39:27
 Re: massey harris 22 wheels in reply to charlie, 07-12-2004 07:06:04
You must have a standard wide front model 22 if you have 28" rear rubber. I think the 32" was found on the rowcrop models and those rears would have been adjustable I think. So you'd need to replace the axles too if you got some 32" cast hubs with the steel rims. I'm not sure about this.
parts man
07-12-2004 16:23:13
 Re: Re: massey harris 22 wheels in reply to Alberta Mike, 07-12-2004 09:39:27
The 32s were a one piece 9 bolt pressed steel rim.
David B
07-12-2004 19:41:03
 Re: Re: Re: massey harris 22 wheels in reply to parts man, 07-12-2004 16:23:13
You may find those pressed steel wheels on the 20's and 22's only have 7 bolts holding them to the hub. most RC's had 32" tires but some RC's had 28"
charlie
07-13-2004 07:50:17
 Re: Re: Re: Re: massey harris 22 wheels in reply to David B, 07-12-2004 19:41:03
i have a mh22 rowcrop with adjustable wide front. it has 28" pressed steel wheels with 7 bolts. i was hoping to find 32" wheels that would bolt right to these hubs. the rear sits pretty low.
