1950's m/f 150 stuck out of gear
boman
07-15-2004 03:31:34
Hope this is not a double posting. Had error message on first attempt, Anyway, a friend has this tractor. He had ran out of fuel and had someone pull it of to start it. I think he said it started but dies going down the road. He had it pulled to my place and the filter was drained and put back on. A little stater fluid and it started. This is when he found out the hi-lo shifter was not engaging. The other gears seem to shift as they should. It had been working good before all this happened. I am wondering if something happened when he had it pulled to start it. Any plates that can be removed to check the problem and correct it? Shifting column maybe? Thanks for any info.
