Hey! Dean Matt I found my clutch problem!
BILLY CATHEY
03-31-2000 14:33:37
Hey guys, I split my 65 this morning! It has a brand spanking new clutch, PP,discs & throwout bearing in it, BUT..... The primary (11") disc was shattered, all the rivets were sheared off. The flywheel has a fresh resurface on it. Luckily there are not any craters from the pieces.
All I need now is a part # for the clutch disc. MF 65. Does it cross reference with any of the other models? My ser.# is 654039 with by my book makes it a 1958 year model. A new clutch and I'm off n gone. Thanks for all your help....
Billy
Jack in NB
04-01-2000 04:19:00
 Re: Hey! Dean Matt I found my clutch problem! in reply to BILLY CATHEY, 03-31-2000 14:33:37
Hello Billy -
Lucky!
516 068 M1 is the current number for the 11" plate. Fits 35 thru 265.
When you put it back together, take your time. Check the pilot bearing. It's a 6203.
If you haven't got a manual yet (I&T is great, and a bit cheaper), hollar - I've got the assembly instructions written up.
Good luck!
Jack
Billy Cathey
04-01-2000 20:28:35
 Re: Re: Hey! Dean Matt I found my clutch problem! in reply to Jack in NB, 04-01-2000 04:19:00
Thanks Jack I'll take all the info. I can get! If you have anything set up to email that's great.
I gotta finish this one so I can start on an 801 powermaster ford. Been sitting at the farm for bout 15 years, I thought it's time to put her back to work. This 65 will be good practice to get into it...
Thanks again
Billy
