Sibby(Aus) MF 168 178
Bob
07-15-2004 15:35:36
You previously stated that 168 and 178 models had a spacer between the transmission and differential housings that lengthened the wheelbase. What was the reason/purpose of this?
sibby(Aus)
07-15-2004 15:56:30
 Re: Sibby(Aus) MF 168 178 in reply to Bob, 07-15-2004 15:35:36
Bob, The 168 and 188 had the spacer piece, the wheelbase is then a bit longer. Somebody else stated that the rear end oil capacity is increased, also may be adapted to drive a front diff. I only seen one converted and the front of the tractor was very high, also had a very large turning circle. cheers, sibby.
DP South Wales UK
07-16-2004 11:10:25
 Re: Re: Sibby(Aus) MF 168 178 in reply to sibby(Aus), 07-15-2004 15:56:30
Hi Sibby, Bob, and everyone else.
I believe a firm by the name of 'Selene' made retro-fit kits for most MF 100 series tractors. Some photos of 4WD's can be seen on a site run by Jarle Eltelevest in Norway. It's Massey Ferguson Heaven!!!! Have a look at the 165's, you might see something a little familiar.
Regards
DP
Link
start.htm
Bob
07-15-2004 17:22:40
I had the opportunity to take a good look at a 178 today. It did not have the spacer. I don't beleive either of these models were ever marketed in the U.S. I have never seen a 168 and have only seen 3 178s. They probably slipped accross from Canada.
sibby(Aus)
07-15-2004 22:17:08
 Re: Re: Re: Sibby(Aus) MF 168 178 in reply to Bob, 07-15-2004 17:22:40
Bob, The 178 was more or less a later version of a 175, with a 4/248 Perkins instead of the 4/236 Perkins. The 168/ 188 was a later version of the 175/ 178. They were all very popular down under. Cheers.
William Bos
07-15-2004 16:33:57
Hi,
From what I have seen on the net, there were 2 conversions for the 100 series. The Saleen conversion had a spacer between the tranny and the 4wd ran off of gearing in this spacer. The Schindler conversion ran off a PTO ( Like the 271XE ) from the rear of the tranny. The driveshaft goes from the front axle under the running board on the left side to the PTO. ALmost bought a 135 Schindler last year, only $5,50 CDN, but someone beat me too it. The next time I see one, IT WILL BE MINE!!
Oh Well
Take care
WIll
pudding
07-18-2004 03:28:24
 Re: Re: Re: Sibby(Aus) MF 168 178 in reply to William Bos, 07-15-2004 16:33:57
ya..... ...my family had 135,148,175,178,188 in there time..... .now have 135 gas, 135 diesel, 165 and 285
actually i have pics of the 188 with factory fitted 4wd..... ..it was a 1979 model
the 8 series was a great tractor..... .brought with it..... the better backend ..... pto and hyd
the ones with the dual pumps are still good loader tractors
William Bos
07-18-2004 06:45:58
 Re: Re: Re: Re: Sibby(Aus) MF 168 178 in reply to pudding, 07-18-2004 03:28:24
Hi,
Did all tractors in the 10 series have dual pumps? I saw a 135 4wd, but sadly I missed it. Was only $5,500CDN too!!
Willl
DP South Wales UK
07-18-2004 07:17:48
 Re: Re: Re: Re: Re: Sibby(Aus) MF 168 178 in reply to William Bos, 07-18-2004 06:45:58
Not all tractors in the UK. Second pump not needed if the tractor did not have ipto, spool valves or multi-power.
DP
sibby(Aus)
07-18-2004 16:02:49
 Re: Re: Re: Re: Re: Re: Sibby(Aus) MF 168 178 in reply to DP South Wales UK, 07-18-2004 07:17:48
Hey fellas, didnt the 168 and 188 have an extra spacer between the front of the engine and the front end housing? cheers for now.
