1945-46 junior 101
B wood
07-22-2004 18:05:32
I was wondering what the horsepower rating is for the Junior 101 with a Continental engine? What are the weak points? There appears to be a type of lift system on the housing behind the seat one side of the splined shaft is twisted off!! This is obviously a weak point... is this a type of 3 point hitch? Does it have a trans driven pump? Any information would be appreciated.
Thanks bw
Alberta Mike
07-23-2004 20:29:20
 Re: 1945-46 junior 101 in reply to B wood, 07-22-2004 18:05:32
Sounds like the PTO shaft is messed up there at the back. The lift system might be getting hydraulic feed from a pump in a number of places. Obviously, the rear PTO isn't one of them since it's fried. Some hook a pump to the belt pulley shaft (pulley removed). Others have a pump coupled to the front of the crankshaft (behind the grille area). Factory pumps would be on the front right of the engine opposite the governor. I would say about 20 HP or thereabouts assuming you have the 140 or 162 version of that engine. The early ones were 124 cubic inches, same engine though, just a different cylinder bore size. I don't think any Juniors came with a factory rear lift, maybe yours is home made or an aftermarket unit. Follow the hydraulic cylinder lines back and you've got to find the pump.
B wood
07-24-2004 05:41:16
 Re: Re: 1945-46 junior 101 in reply to Alberta Mike, 07-23-2004 20:29:20
Thanks for the reply mike!
B.W.
