Tractors with glow plugs
Chad Gillis
07-27-2004 07:52:36
My company manufactures OEM glow plugs for CASE and JOHN DEERE. I am currently trying to find out what other tractors/AG equip requires glow plugs. Anything will help! Model numbers and OEM glow plug part numbers or aftermarket brand part numbers. If anyone is in need of JD or CASE plugs, I can help you out.
Don-Wi
07-28-2004 21:05:04
 Re: Tractors with glow plugs in reply to Chad Gillis, 07-27-2004 07:52:36
Oliver/White deisels used them also
William Bos
07-27-2004 13:56:34
Hi,
Here is the part numbers for the Perkins ( MF and Perkins part numbers )Thermostart for the A3.152 Perkins 3 cyl diesel.
MF 893 501 M91, Perkins 2666103.
....and the part number for the Standard 23c 4 cyl diesel ( 4 glow plugs needed ) 829162M1
Take care
Will
txblu
07-27-2004 09:40:05
Early '60 Ford diesels used 2 in the intake manifold.
txblu
07-27-2004 09:43:13
 Re: Re: Tractors with glow plugs in reply to txblu, 07-27-2004 09:40:05
'65 Ford diesel (3 cyl) and MF 35 used one which combined heat and dripping diesel. Seems it would get hot when commanded, heat up which would release a plug allowing diesel to drip on the hot coil, which ignited and the engine ingulfed
"GREAT BALLS OF FIRE" (Jerry Lee Lewis hit)
And that is the truth. This one cost about $65 at the blue house.
Mark
ken sampson
07-27-2004 20:00:18
 Re: Re: Re: Tractors with glow plugs in reply to txblu, 07-27-2004 09:43:13
Farmall 560 diesel needs 6 of them. Sorry don't know the part numbers though.
