What MF255 engine is mine?
Brad in IN
08-03-2004 07:27:48
I hve a deisel MF 255. I was wanting a water pump for it. There are two to choose from in this website. Are there markings on the engine somewhere?
Tommy D6-8U
08-08-2004 16:14:40
 Re: What MF255 engine is mine? in reply to Brad in IN, 08-03-2004 07:27:48
Brad,
The 203 engine should have a JE at the beginning of the engine serial number and should have the exhaust manifold on the left side, intake on the right. The 236 engine should start out as LD and the manifolds are both on the right side of the engine. I work at a Perkins dealer; I can get you some info on it if you need it.
Tommy
MF
08-05-2004 15:43:35
I checked the 1975 MF255 today and there is a tag on the right side of the engine near the top that said 203, very faint. Don't know about the 236?
mowr
08-04-2004 17:04:45
Yes, the numbers should be found on a tag and/or stamped into a machined pad on the engine.
