44 massey harris fan belt
adj
08-07-2004 15:10:07
I can not find a new fan belt for my 44. Does anybody know where they can be purchased? Also I have switched engines and have spacers or washers that I do not remember where they go. I pulled the radiator and the engine. I am thinking that they go under the motor front. Any ideas? Thanks, Art
adj
08-08-2004 15:48:54
 Re: 44 massey harris fan belt in reply to adj, 08-07-2004 15:10:07
Thanks for the information ,Harris Guy. I found a Tisco dealer 23 miles away. How do you align the engine? adj
Harris Guy
08-07-2004 16:17:17
Replacement parts, through Tisco, had the belt. I believe the # was 35645A, perhaps changed. The
front engine mounts should have had shims, when the bolts were removed. The drive train, coupler
flange, under the battery, will take added stress
without the proper engine alignment. Unless you
check alignment, now, you will be lifting that engine forward, to replace flange parts, in months, year(s?).
