MF 35 Deluxe
Chip
04-03-2000 10:24:46
Just read a post that showed serial number prefixes (From Jack in NB). My serial number is SNM 207949, which from Jacks post, shows it to be a standard clearance, standard diesel, dual clutch. Everything agrees with that theory except that I have the Perkins diesel, which should show SDM, right? So now I'm wondering if someone changed the dash and left someone elses I.D. tag in place, someone changed the engine from a Standard to a Perkins, or Jack is in error, (No offense intended). Does anyone have the ability to verify tractor age/model by using the engine number?
Jack in NB
04-03-2000 11:51:26
 Re: MF 35 Deluxe in reply to Chip, 04-03-2000 10:24:46
My face is red.
The D is Standard, N is Perkins.
Must have been the spring fever!
There are a couple of sites with serial number references; try the tractor numbers at the left of this page.
Chip
04-03-2000 18:22:26
 Re: Re: MF 35 Deluxe in reply to Jack in NB, 04-03-2000 11:51:26
Jack,
Thanks for your quick response! I can't tell you how relieved I am to see that it was just a mix up.
Regards
Chip
Suffolk, Virginia
