Oil Leaking around Tach Cable on 135
BB
08-18-2004 19:06:59
My 135 is leaking oil somewhere around the tachometer cable where it connects to the block. It appears to be coming from there anyway. Is this a common problem. It runs down the side of the engine and drips after it is run for a while. I would like some advice on fixing this problem. I hate a leak. Thanks for help in advance.
BB
Big Dean
08-19-2004 06:37:41
 Re: Oil Leaking around Tach Cable on 135 in reply to BB, 08-18-2004 19:06:59
The adapter that bolts to the back of the engine has a seal in it the seal has probably got hard from the heat of the engine over the years and has started to leak. when removing the adapter from the engine be carefull they are easy to break.
