MH 20 rear wheel removal
buck
08-19-2004 16:15:30
trying to remove rear wheels. what is the center hub part of the wheel and how do I remove it? It looks like it would have to come off first before the actual wheel or is it part of the wheel? it has two "notches" in it, close to each other at the edge. I can not find it in the parts or service book that I have for the tractor. thanks.
mowr
08-21-2004 03:30:34
 Re: MH 20 rear wheel removal in reply to buck, 08-19-2004 16:15:30
Nice picture, Buck. It looks to me like rust and paint have your wheel disc stuck to the (cast iron) hub. You're smart to leave the lug bolts in 'til the wheel is loose enough to remove it easily. I use a 4 lb. sledge hammer and a large round brass drift to rap on the disc between the lug bolts (not hard enough to dent the disc). This to break loose the rust and paint. Then push and pull on the top and bottom of the wheel/tire. Time and patience! I suspect the "notches" are pry points to help bring the disc out once you have it far enough to get a tool in there. (Don't bend the rim). Wish you success!
buck
08-20-2004 11:04:37
third party image
I have tried to attach a picture to show the wheel. Hopefully it will work (first time doing this).
As far as the wheel goes, it looks like the center piece is not a wheel wieght (looks very thin). However, it also seems to be centering the actual wheel on the axle, which makes me think it has to come off first.
Appreciate any ideas on removal.
Thanks.
Roy in UK
08-20-2004 01:46:49
Is it a wheel weight your looking at?
mowr
08-19-2004 22:04:03
I can't see what you're describing so it's hard to give a short answer. Unless it has some kind of adapter or spacer (as for dual wheels) it should come right off but may have rust buildup between the axle flange and wheel disc (and brake drum if you're going that far). If yours had a two-piece axle/flange, it seems like it would have obvious mounting hardware to remove.
