Can't get pto ingaged
Bonnan Bui
08-20-2004 21:38:07
I'm having more difficulty getting the pto on my MF 65 ingaged. Resorting to shutting off engine and then restarting. Has anybody had this trouble??
Big Dean
08-21-2004 09:22:56
 Re: Can't get pto ingaged in reply to Bonnan Bui, 08-20-2004 21:38:07
Your internal PTO clutch adjustment probably needs to be adjusted. It is done up through the hole in the bottom of the bellhousing. The book calls for a clearance of .090 + or - .002 between the stop bolts & the fingers of the PTO pressure plate. In most cases that is to much clearance for the PTO clutch to release usually .050 to .060 works much better. I have a picture that shows how to make this adjustment If you want to E-mail me with your E-mail address I will send it to you.
