monroetufline Disk
Charles
08-24-2004 07:20:19
I am in the market for a set of Disc and have came across to be a faily good set(monroetufline) although, I have not used them yet. I am looking at the THF72022 Model, which weighs 1055Lb, 6'8" cut and 22" blades I will be using this model with a 135 Cont, gas. All input apprciated.
Phil in MS
08-27-2004 09:49:24
 Re: monroetufline Disk in reply to Charles , 08-24-2004 07:20:19
Charles,
I would be concerned that this Tufline unit may be a little too much disk for your gasoline tractor. I guess it might depend on how much ground you intend to work year. Just a garden spot might not be too much but unless you have pretty wide rear tires and good front weight that seems a little heavy. You may hear from some who have the 135 tractor and they would have better experience. Good luck.
