Hydraulic Remote
C W Cabalo
09-15-2004 19:43:18
I need to install a remote on a MF245. I ordered a diverter valve that sits in place of the civer cover. The cover has a stand pipe that go's into it and am not sure how to disconect it. Also after I do get the valve in place what would be my next step. The valve had no instalation instructions with it. Thanks.
CW
Thomas
09-16-2004 12:19:42
 Re: Hydraulic Remote in reply to C W Cabalo, 09-15-2004 19:43:18
Remove the blanking cover, sometimes the stack pipe comes out with it, sometimes it doesn"t. Pull it out if not, and change the o-rings - they are pence to change and saves a job later when they fail. Carefuly refit the stack pipe, ensuring that it does go back into the hole in the pump and pushes home - you will be able to feel it when it"s right. Simply fit the diverter valve and bolt up - you may need longer bolts or cap heads depending on the valve"s design - fitting an o-ring to the port underneath. Some diverter valves include a return port, some do not. If yours doesn"t then you"ll need to make a return. Common solutions are a tapped port on one of the centre housing side covers, or a pipe brazed onto the filler cap, the former being better.
C W Cabalo
09-16-2004 12:55:17
 Re: Hydraulic Remote in reply to Thomas, 09-16-2004 12:19:42
Thanks Much.
