hydraulic Backhoe lines MF 50 1972
bman
09-18-2004 14:53:33
I started a MF 50 frontloader with an industrial backhoe again after it has not been used for 15years, new battery, some cooler water and it started instantly. the only problem I got are the hydraulic lines from the Backhoe. there is not one without a hole. Got no manuals. Please has someone got instruction or ideas of how to open the backhoe arms or at least how can I get to the hoses? considering I cant move the backhoe much as all lines are gone! How do I connect new hoses inside the arm special long tool? Every info helps. Thank you.
Leland
09-26-2004 18:15:42
 Re: hydraulic Backhoe lines MF 50 1972 in reply to bman, 09-18-2004 14:53:33
Are you talking steel lines or rubber hoses?
bman
09-27-2004 17:09:55
 Re: hydraulic Backhoe lines MF 50 1972 in reply to Leland, 09-26-2004 18:15:42
Steel lines and rubber ones, but I somehow managed to get the backhoe arm in to a straight outward position and removed the hydraulic cylinder. From than on it was no problem changing the hoses. Still waiting the parts to be shipped here to Suriname. Got a different problem now, since 2 days now the MF50 Tractor is loosing its power. I am working only on a quater of his usual operating power. After I turn the MF50 off for few minutes and restart, the power comes up again for a very short period. My guess its a diesel fuel problem but I changed all two Super-fine-fuel-filter elements (OK they were very dirty) and removed all the rest air in the fuel lines. It cant be the airfilter. Next thing I need to do is to take the fuel pump apart and have a look. If anybody got some other suggestions please they are all welcome.
bman
09-28-2004 16:38:14
 Loosing operating power MF 50 1972 in reply to bman, 09-27-2004 17:09:55
Changed the fuelpump today new, cleaned out the tank, aired again the fuellines. Power came back for over 30min, than suddently looses so much he cant even move himself anymore. turned off- waited 10min start up again worked fine for 15min lost power turned off.... Help anyone Please! Got suggestions what could be the problem?
