Anyone have an MF 41 sickle bar mower?
Adam P
09-21-2004 17:59:27
Hello,
I have been searching for a sickle bar mower for my MF 245 tractor..... a fellow has one for sale that has been kept in a shed, he spent $500 in maintenance on it last year at a dealer, and then this year bought a disc mower. He wants $600 for it. Anything special i should look for before buying it? I want to be certain it is in good repair and that ut us a good unit.....
Indydirtfarmer
09-22-2004 04:06:05
 Re: Anyone have an MF 41 sickle bar mower? in reply to Adam P, 09-21-2004 17:59:27
I've owned a couple of 'em ovcer the years. Good mower. Also look for bent, or mis-aligned parts around the hitch frame. If they were not mounted properly, they would end up getting bent there. I bought one for parts because it was twisted beyond straightening. With that much spent on it, the mower SHOULD be in great shape. We cut hay with one for I replaced mine with a Deere #350 mower last spring. LOTS more money, but not that much better of a mower. John
thebigron
09-21-2004 19:05:06
Look on the top of the bracket that fits under the left link assembly arm , ( You will be removing the sway bar before mounting the mower).All the time that the mower has been in use it will have been wearing at that point. That wear or lack of wear will state volumns about the mower. If it seems to be worn down much more than an eighth of an inch, that would indicate that it has been in a use a good bit. Not to say the dealer has not got the mower in good shape now, and if indeed $500 has been spent recently, it sounds like a decent deal. You will have you a good mower for ditchbanks and ditches. Good luck.
