electrical problems
blister
10-05-2004 10:42:26
I have a 58 mf 65 that runs on an altenator. I have a loose wire and I'm not sure where it goes. I believe it connects to the ignition switch but I don't know which of the 3 connections to attach it to. If I start the tractor and disconnect a battery post the tractor dies. If I start the tractor and touch the loose wire to two of the three connections and then let the loose wire hang freely again then disconnect the battery terminal, the tractor will continue to run.
Blister
10-05-2004 11:45:03
 Re: electrical problems in reply to blister, 10-05-2004 10:42:26
I just know it is a chevy alternator.
Bob
10-05-2004 11:00:54
If it is an INTERNALLY REGULATED Delco, alternator, there's help HERE:
Link
Otherwise, you'll have to let us know what you've got!
allanC
10-05-2004 22:31:25
 Re: electrical problems in reply to Bob, 10-05-2004 11:00:54
Assuming it's a delco with a built in regulator it needs power to the connector farthest from the main battery connection. The close pin is the idiot light, Some early regulators had to have this connected through the light to start charging but It would be rare if you had one that old.
