MF 65 Perkins engine
bigdog746
10-28-2004 10:47:10
overhauling a perkins 4-203 one sleeve does not fit the bore tight can be pulled out or in fairly easy by hand what would be the remedy to hold it in place
Big Dean
10-28-2004 14:11:53
 Re: MF 65 Perkins engine in reply to bigdog746, 10-28-2004 10:47:10
There is a loctite for holding loose sleeves it is the green loctite if I remember right. It has been several years since I have used any of it. I usually had the block bored an a sleeve pressed in then bored that sleeve back to the original bore of the block. Then you can put the replacement sleeve in they last a lot better when done this way.
