MF 245 smoking
CH
10-28-2004 17:11:01
Back in January there was a post about a 245 smoking. Did the person who wrote the post ever find the problem? I've been restoring a couple other tractors and haven't gotten to work on the 245. I'd appreciate any help.
chief 83
10-31-2004 16:26:32
 Re: MF 245 smoking in reply to CH, 10-28-2004 17:11:01
I have a 245 and it smokes a bit when it's cold. Much less after it warms up but there's always a hint of blue. Runs great. Unless it's using a bunch of oil or its making it difficult to breath do what a guy told me--worry about something else!
phil25
10-30-2004 17:20:15
Good Day: I don't remember seeing the post you mention but i had a 25 diesel that was making a black slurry on the exhaust piping, and a bit of bluish exhaust fumes at times. Actually it was puffing smoke out in a random pattern.
Repair involved changing the thermostat to a 190 degree unit, as the orginal unit had stuck open and i couldn't get enough engine heat to prevent consdation of the exhaust gasses. runs clean now and only smokes when loaded up hard, and , even then its a blackish smoke from overload conditions.
hope it helps.
CH
10-30-2004 19:38:22
 Re: MF 245 smoking in reply to phil25, 10-30-2004 17:20:15
Thanks Phil,
This one was a bit different. A lot of bluish white smoke when cold. Clearing off somewhat when warm. The post was leaning toward low fuel presure or injector timing or a injector timing problem caused by fuel preasure or lack there of.
Thanks for thge reply.
