If you can do a compression check, might try that. Rings could be stuck from sitting, or cylinder walls rusted (pitted). Diesel has to have that squirt of fuel, allright, but without proper compression to develop the air hot enough to explode the fuel, it's hopeless. I would think if your pump were the problem, it wouldn't wait till the engine is kicking over to join the party. It would be there during cranking. Solution: Crack the fuel line at the injector. Crank the engine. If you see fuel pfft pffting from under the nut, the pump is a pumpin. Don't forget to lock the nut back down. (Sometimes we forget the simple things.) I'd add some MMO to the fuel or some kind of solvent to loosen the stuck rings if that's the problem. Cylinder walls will (should) fix themselves with a little wear. Run it for a half hour or so (after installing MMO in the fuel tank...I'd put in like 2 oz per gallon of fuel this time) then put a load on it (plow) for a couple of hours and get the temp up. Might be surprised at the difference in performance when finished. Of course you need to watch your engine temp. Doubt you'd overheat it but one never knows. Mark
