Massey Harris 44 year and part ID by #'s
Andy C. B.
11-06-2004 16:46:36
I have an old 44 diesel it is a 4 cylinder and we bought it as a basket case because it is a single wheel. anyway the following #"s we have found as we have cleand. On the right side of the motor we found HD 260 A O P B 7 P On the left side by the break we found 7633 96 M 2 and on a raised casting directly below was 3 26 52
We also found the following #"s on the crank and we are not sure if the crank is the correct crank for the engine On the front journal was 1 33 (stamped in) On the rear journal was HD 260 C 2 04 M
Any and all input would be appreciated ANDY
msb
11-06-2004 19:14:50
 Re: Massey Harris 44 year and part ID by #'s in reply to Andy C. B., 11-06-2004 16:46:36
The 3/26/52 was the day the casting was poured.Your tractor is a 1952 model.
jf
11-06-2004 17:58:39
Check the top of the rear end next to where the seat is mounted. It should have some letters and numbers. That will help for info.
