mf 135 hyd filter question
Bob S
11-11-2004 13:29:56
i see in a previous post about the ''wire '' on the hyd filter as this is my first 135 gas,where is filter located and how do you get at it and is it to be cleaned or just replaced?
any and all ideas appreciated
Gerald J.
11-12-2004 07:38:27
 Re: mf 135 hyd filter question in reply to Bob S, 11-11-2004 13:29:56
Get thee an owner's manual. Make life better for the tractor.
The filter is on the pump inlet and is just inside the cover that holds the PTO shift lever. That's below the full oil level.
Its a metal mesh screen. It could have come apart, mine did, so then needs replacement. Sometimes it can be cleaned. Then read the admonition (comes from the owner's manual) to pick up the two caps with the filter to keep from dropping the grunge into the pump.
Gerald J.
