135 steering shaft question
Bob S
11-13-2004 13:40:02
on a 135 with power steering the shaft that the steering wheel is attached to moves up and down about an inch, depending which way you turn wheel.should note tractor has all the power components except the pump for steering,came to me this way,i plan to install the corect pump later,also all lines have been removed and blocked at steering box area. any and all ideas appreciated
Gerald J.
11-13-2004 17:09:51
 Re: 135 steering shaft question in reply to Bob S, 11-13-2004 13:40:02
Sounds a little worn, but some up and down motion is what runs the power steering valve.
Gerald J.
