White smoke is most often from coolant. Neither fuel or oil. The carburetor tune up instructions should include the distance the float should be from the carburetor separation flange when the valve is closed. There should be two mixture adjustments, one for idle (often an air adjustment) and one for high speed or loaded. You adjust the idle mixture with the engine running as slow as possible. The governor will hide the results of your adjustment, but you can often use the throttle plate position as indicator of best mixture. You slow the engine down as slow as you can (might have to back off the idle speed adjustment on the throttle segment) and adjust the idle mixture for the least throttle opening. Or you pull on the governor rod to close the throttle and while holding the throttle closed you adjust for fastest idle speed with the idle mixture screw. For the high speed/power jets, I adjust that for the fastest speed pulling a plow with the plow pulling hard enough that the speed is below what the governor would run. That usually results in the mixture being on the rich (a bit of black smoke) side but the engine runs coolest with the greatest power under that condition. Setting it leaner can improve efficiency though and may eliminate the black smoke on acceleration. These two adjustments interact so you have to alternate them a few times until you find no improvement in either. The choke should open completely when the choke button is pushed all the way in. You may have to take off the air intake hose to check its position. There may be an adjustment for accelerator pump output and its set for a bit too much. Lowering the float (increasing the distance from gasket flange when the float valve is closed) will lean the mixture under all conditions, but I don't know about that effectively reducing the output from the accelerator pump. It may be that the orifices that the accelerator pump discharge from have been enlarged by excessively aggressive cleaning and need to be replaced. An economical engine carburetor adjustment will leave the exhaust pipe interior coated with something gray, not black. But not much of a coat at all. Some of this is in the owner's manual, some in the shop manuals, some in automotive shop manuals. I've read many, so I can't be sure exactly where each bit of information came from. Gerald J.
