Harris Guy
11-18-2004 08:20:18
Re: Char Lynn in reply to Brian L, 11-18-2004 05:21:44
What is the required part? Since Eaton owns Char-Lynn, and after market PS is not selling like it was 3 or 4 decades ago, you get ignored by the company. The Rep wants to visually see the part you need, even when you have their part number. Best offer, with arm twisting, was he would get a machine shop to custom make the part. There are as-is units sold on the net , regularly. I saw one non-working, a guy paid $400+ for. Running the motor valve, with a flow control, seems less of a problem, than secondary pumps, if you have central hydraulics on your tractor. Hydraulic Surplus, of NE, has the Prince control, all 3 can be set at 1000PSI, for the steering. Slows your central hydraulics, some, but antique tractors don't get run that hard, usually. Good luck.
