type of engine
brendan
11-27-2004 13:23:14
Im trying to find out about atractor ihave.ihave tried afew sites but knowone seems to be able to tell me which type of engine is in it by the numbers i have. ITs a3 cyl it may be from m/f 50 the numbers i have are 1106384 above pump on block behind pump k228/co280098f bottom right block 2gkn/1372 all on same side of block. I hope someone might be able to help with this.Gerry
Ray,IN
11-29-2004 20:46:00
 Re: type of engine in reply to brendan, 11-27-2004 13:23:14
You must supply the make of the tractor, to establish a beginning point for identification purposes. If you think your engine was taken from a MF50 just click on the serial numbers link at the left and locate your tractor serial number. If all you have is the engine casting numbers, and don't know what tractor it is from, it may be difficult to positively identify. Have you visited a MF dealer yet with your numbers?
blazebfd
01-08-2005 06:24:53
 Re: type of engine in reply to Ray,IN, 11-29-2004 20:46:00
On a similar note: I have a MF industrial, ser. no. 9A 89xxx, 4 cyl gas engine casting no. 37112520/4 A119. It is apparently a 1970 model, I think this is a MF30. How do I differentiate between the Perkins gas and the Continental engine?
brendan
11-30-2004 13:14:48
Thanks for your reply Rayin.I have tried most sites with these # but none seem to regonise these # the engine is in a super dexta. THE FORDSON sites dont regonise them.ITis a3 cyl perkins there is parts on engine which show it not a dexta .this is my reson for trying this site.Ihave also tried perkins marine england with out sucess.REGARDS Brendan
cdmn
11-30-2004 18:10:39
 Re: type of engine in reply to brendan, 11-30-2004 13:14:48
Perkins used to sell conversion engines for the Ford 8N, NNA, etc. When Ford developed the Dexta, they made an arrangement for Ford to supply the iron castings and Perkins to do the machining. It's possible you've got an older Perkins engine in your Dexta.
brendan
12-01-2004 12:42:11
 Re: type of engine in reply to cdmn, 11-30-2004 18:10:39
Thanks for your reply cdmm.Iknow about the link up wihth the ford / perkins.The problem i have is trying to find out if eigine is a152 or p3144.I thought i could do this by engine number.The pump on engine is a simms mimmec type ,these were only fitted to 152 as i am aware 62/ 64 engine.If it were an earlyer type ithink it would be a pnemanice type.BRENDAN
