MF135 engine
Brady
11-30-2004 05:36:52
I have a MF135 with a Perkins 3 cylinder diesel engine. How do I determine whether it is a AD3.152 or a 3A.152? Someone is selling these and other engine overhaul manuals on ebay. I want the manual but don't actually know which engine I have.
Big Dean
11-30-2004 07:37:57
 Re: MF135 engine in reply to Brady, 11-30-2004 05:36:52
The MF135 has the AD3-152 engine in it I did have one in the shop one time that someone had installed one of the older A3-152 but it would be very rare to find that.
ben uk
11-30-2004 08:42:52
 Re: MF135 engine in reply to Big Dean, 11-30-2004 07:37:57
Hey big dean, how can i look at the engine and tell if its ad3 of a3? My 135s engine was made in august 64, before 135s were bring built here in the UK. The tractor has no serial plate so its difficult to find its age but it seems older than the really early ones. Has the later hydraulics etc, square mudgards etc.
Cheers, it would explain a lot if it does have an older engine in it!
Ben
Big Dean
11-30-2004 09:52:20
 Re: MF135 engine in reply to ben uk, 11-30-2004 08:42:52
Ben As far as I know all MF135 diesel engines were the AD3-152. The old A3-152 has three combustion chamber three corner plates on the left side of head & the Injectors set straight up and down. The AD3-152 the Injectors set at a slight angle in the head and they do not have the combustion chamber plates.
ben uk
11-30-2004 11:12:32
 Re: MF135 engine in reply to Big Dean, 11-30-2004 09:52:20
Cheers big dean, ill check that in the morning.
Bill Darte
11-30-2004 09:20:00
There is an engine serial number either right or left side on the block just below the heads. This # on mine (1970 model) is UA 152..... (don't have it here).
I have tried to get a dealer for Perkins to go directly to Perkins to find out the date of manufacture for the engine as I wanted to see whether my engine and chasis are original to each other....no luck getting a response.
Anyone know of another source of this info?
bd
ben uk
11-30-2004 09:28:34
 Re: MF135 engine in reply to Bill Darte, 11-30-2004 09:20:00
My date was on the underside of the engine right at the front.
But not sure if its the original engine, thats what im trying to work out as well!
Brady
11-30-2004 08:19:21
Thanks, Big Dean
