throttle linkage
chris lucido
12-09-2004 15:28:00
I have a massey ferguson 50. At idle the engie idles fine, but as soon as you move the throttle just a little bit, the engine runs wide open. I need advice on how to adjust this throttle linkage if it is the trouble. Thank You
chris lucido
Paul in Ontario
12-09-2004 17:51:08
 Re: throttle linkage in reply to chris lucido, 12-09-2004 15:28:00
I would check and make sure the govener is working. The weights or balls might have fallen out. With out them there is nothing to push the throttle spring back when the engine is at a set r.p.m. or throttle position. Good Luck
