General 55 555 MH Questions
BMassey
12-11-2004 08:12:40
Can someone explain a 55 serial number meaning to me. I have viewed the MH serial numbers on this website but the one I have doesn't make sense, 55G1SFL1314. Could one or more of these letters be a transscription error? Also, was the 555 offered with the 3 point hitch option?
Thanks
Bruce C
12-12-2004 10:05:30
 Re: General 55 555 MH Questions in reply to BMassey, 12-11-2004 08:12:40
All the 55,s and 555,s I have seen have the full wheatland fenders as they are called.Massey-Harris built a regular altitude which is designated by the number 1.The high altitude is designated by the number 5.The main difference between the two is the jetting in the carburetor.On your tractor check on the top of the frame just ahead of the clutch pedal the serial number is stamped into the frame.It is possible that your number was stamped wrong on the number plate.I check the serail numbers I have for the 55,s and 555,s and there is no L,s in the list.I,m sure the L in your serial number should be a number 1.Drop me a line on hot mail and I can send you the serial numbers lists I have.
Bruce C
12-11-2004 15:54:40
It is possible that the l should or could be a one.If it is a one the tractor would be a 1952 model.
Edchainsaw
12-11-2004 21:20:24
 Re: General 55 555 MH Questions in reply to Bruce C , 12-11-2004 15:54:40
I am pretty sure that G1 means Gas with low altitude pistons...
Edchainsaw
12-11-2004 14:48:20
55series tractors never had 3pts..
now the serial #s.. help me guys...
but I believe 55G1SFL1314
means 55 series... Gas --low altitude pistons, standard wheel tread foot clutch but L I aint sure of...
Edchainsaw
12-11-2004 14:48:08
BMassey
12-12-2004 08:30:05
 Re: General 55 555 MH Questions in reply to Edchainsaw, 12-11-2004 14:48:08
Thanks for all the replies. I knew the 55's didn't have the 3 point option, wasn't sure about the 555. I am also stumped about what L and the 1 means in the serial number. But you guys have taught me something because I would never have know about low altitude pistons and standard tread. I had figured out the gas and foot clutch part. So are you staying this tractor was made in 52. The serial number website had me thinking maybe 47, but I have a novice at this.
Also, were 55 standard tractors only available with clam shell fenders or could you special order the wheatland style?
Thanks again guys, I really enjoy this website, don't contribute much but have learned alot!!
marlowe
12-11-2004 11:19:04
the 55 and 555 never had 3 pt.
