multi -power
charles mcclint
12-12-2004 09:57:27
135 six speed mh,,,freewheels in all gears,,,,whats the problem ?
Lee in MI
12-12-2004 11:19:01
 Re: multi -power in reply to charles mcclintock, 12-12-2004 09:57:27
It will free wheel in 'LOW' multi-power. If it does it in 'HIGH' than the multi-power is not enaged or the unit is broke. It could be that the linkage is disconnected or needs adjusting at the bellhouse area. Some people disconnect the linkage so if it has a leak it doesn't leak if they're going to sell it.
Roy in UK
12-12-2004 11:16:02
You should have engine braking when in high multipower but not in low. ( A bit of a pain I know)It should say on the multipower switch "Shift to high for engine braking". By the way you cannot tow-start a multipower tractor.
Gerald J.
12-12-2004 10:47:56
That's normal in multipower in one of its two ranges. It doesn't freewheel in the other range. unless the multipower is broken.
Gerald J.
