massey 35 diesel
cameron
12-12-2004 12:10:06
rpm is all over the place . powers up fine but when i take back to idle it takes forever to come back to proper idle it revs high and than slowly comes back to normal idle.suspect pump problems but would like to try to fix at home.same cameron that had problems with 3 point hitch not coming down thanx to all for your help up and down working just fine.
DavidP, South Wales
12-12-2004 14:05:48
 Re: massey 35 diesel in reply to cameron, 12-12-2004 12:10:06
Hi,
Start off by following the throttle rod down to the pump and disconnect the rod. Can you operate the pump lever easily? There is an O ring inside and the spindle can become tight. If this is the problem the top of the pump will have to be removed and the spindle freed. Really it is a job for an expert but it can be done if you are careful and make a careful note of the linkage position inside. Make sure you have a new gasket to go back. Good luck
DavidP
txblu
12-13-2004 07:03:41
 Re: massey 35 diesel in reply to DavidP, South Wales, 12-12-2004 14:05:48
I had that problem on a deere. Figured if that was bad, so were other parts. At least he can shut his tractor down; not like a runaway pump.
I checked on the www and got a 6 cyl pump repaired and returned in 10 days for less than $500. Lotta money, but it's done now and all I have is super performance as a result.
Mark
