G P Wheel seals
44 special
12-18-2004 15:58:23
I need to replace the wheel seals on my G P but I can't seem to find a source for the felt ones, I would replace them with lip seals ,does any one know where I can find something that will work? Thanks
Harris Guy
12-18-2004 16:40:47
 Re: G P Wheel seals in reply to 44 special, 12-18-2004 15:58:23
If you have one intact enough to fabcicate, you can get felt seals cut to size, but they run about
thirty dollars a pair; the more of the same, the less they cost. An old supply house back east, has
NOS from two forgotten gasket compnies. Names like
Atlantic Gasket, etc. You may get lower prices, on the lip style, but I did not persue chasing those down, for 44 seals. Are your felts actually cut to a taper? That is the correct style on dust
cones, for front 44 hubs. I can find a number, if you have interest in felt. GP should pose no problem.
44 special
12-20-2004 16:32:29
 Re: G P Wheel seals in reply to Harris Guy, 12-18-2004 16:40:47
THANK YOU no they are not tapered, I will use any thing I can get.
Harris Guy
12-22-2004 17:22:11
 Re: G P Wheel seals in reply to 44 special, 12-20-2004 16:32:29
The owner has bought up three defunct supply houses, a basement to attic inventory, several names, but most popular one is Mechanic's Bliss.
#508-753-2751, ask for Tim,he runs about, floor
to floor. If you want felt they have no info on
precise size to fit. You could send an axle cap, they would cut a custom fit. Even items like 'o'
rings, in spiral neoprene style, can be gotten by
them, from connected inventory. They have yet to
say 'no, we can't get it'. Good luck.
Harris Guy
12-23-2004 09:23:23
 Re: G P Wheel seals in reply to Harris Guy, 12-22-2004 17:22:11
That above listed number, from information, gets the fax line. Try 508-753-8137, 508-754-4076 for
a talking person.
