ferguson to30.... overheat?
ash
12-18-2004 18:56:46
i have a to 30 that shuts down after it heats up...usually about a half hour...and once it shuts down it will not start back up untl it cooles back down. the motor was rebuilt about a 1000 hours ago...what could this be? any help would be appriciated.
Billy McCarver
03-01-2006 02:55:54
 Re: ferguson to30.... overheat? in reply to ash, 12-18-2004 18:56:46
Hi,
My grandfather had this problem 30 years ago after loaning his TO30 to a neighbor. Calves had chewed up the wiring and the trouble was caused by the neighbor rewiring the coil primary backwards. The tractor would start and run fine until it started to warm up. Eventually, it would misfire enough to quit running and not restart until it was stone cold again. Switching the connections on the coil primary fixed the problem. Hope this helps with your problem. Billy
Sam Henderson
12-19-2004 07:15:46
Check for spark after it heats up and also (if it is gas)check it is not vapor locking or has a fuel line restriction.
Chuck (CA)
12-18-2004 23:34:16
Well, a bad coil could cause that. Is it 6 volts or converted to 12 Volts? I seem to remember a resistor used in a 12 volt conversion that could fail. Can anyone expand on this?
Jerry/MT
12-19-2004 20:03:57
 Re: ferguson to30.... overheat? in reply to Chuck (CA), 12-18-2004 23:34:16
If the reistor fails open circuit, you'd have no primary current to the coil and the engine would not run. The other question, in my opinion, would be does this tractor have a 12V conversion and if it does, does it have a true 12V coil or is a 6 volt coil used with a resitor? If it's the latter, then must be a reistor installed or the coil will overheat. Also, is there any indication of engine overheating?
William Bos
12-18-2004 21:07:07
gas? diesel? more info and someone could probably help you.....
Take care
Will
steveormary
12-19-2004 07:44:45
 Re: ferguson to30.... overheat? in reply to William Bos, 12-18-2004 21:07:07
ash
probably bad coil. never had one vaporlock.
steveormary
ric
12-20-2004 18:39:02
 Re: ferguson to30.... overheat? in reply to steveormary, 12-19-2004 07:44:45
on mine the condencer was the culprit
