rocker arm corks
brucec
12-22-2004 06:03:31
Awhile back I was asking about the corks that seal the ends of the rocker arm shafts. I have since talked to someone who had an MF 202 like mine. He wondered if the oil pressure gauge would indicate loss of the corks, seeing as how its a lot of work to remove the gas tank to get at the cover?
Karl Z.
12-26-2004 14:38:57
 Re: rocker arm corks in reply to brucec, 12-22-2004 06:03:31
I don't think that missing corks will be indicated by low pressure on the oil gauge. Removing the fuel tank isn't that difficult. Just remove the 4 bolts that secure the tank and disconnect the fuel line. The entire tank should then pull right out with out any other fiddling around.
Karl
Gerald J.
12-22-2004 06:54:47
Oil pressure didn't drop on my MF-135. But the lost corks let the rocker arm bushing wear badly and the passage kind of plugged up so no oil got to the head anyway.
Gerald J.
