Front Jack Point on 135 - Oil Pan?
Bill Darte
12-23-2004 11:10:37
Is the oil pan OK to use as a jack point on the front of my 135? Seems like nothing else is available given that I want to remove the cast axle housing and pivot shaft and rest of front end for repair, painting, but sure don't want to break anything....
Thanks for the help
bd
Big Dean
12-23-2004 21:01:36
 Re: Front Jack Point on 135 - Oil Pan? in reply to Bill Darte, 12-23-2004 11:10:37
I jack them up with the pan for 27 years and so did our Massey Ferguson services reps. I never did any harm to one of them just watch the drain plug that the jack is not hitting it. I usually used a wood block between the jack & the pan.
sibby(Aus)
12-24-2004 02:52:19
 Re: Front Jack Point on 135 - Oil Pan? in reply to Big Dean, 12-23-2004 21:01:36
I agree with Big Dean, as long as you place a big piece of wood between sump and jack, since 1970 with no dramas.
DavidP, South Wales
12-24-2004 11:01:29
 Re: Front Jack Point on 135 - Oil Pan? in reply to sibby(Aus), 12-24-2004 02:52:19
OK,OK,OK, I stand corrected. But make sure you spread the load with a block of wood.
Merry Christmas and a Happy Healthy New Year to everyone wherever you are!!!!!
DavidP,South Wales
12-23-2004 11:18:23
No,No,No,No,No
Hi Bill,
The sump may support the weight but it's an expensive way to find out. If you have a loader or not fitted the safest place is under the clutch housing. Slacken the front wheel nuts first. Put a trolley jack under the axle casting and lift the wheels just clear of the floor. Place suitable support (large wood blocks) under the clutch housing (under the 4 bolts) and lower. Remove the wheels and this will give you full access to the axle. Don't forget that you will have to remove the bonnet and radiator before you can remove the axle casting.
Hope this helps
DavidP
Bill Darte
12-23-2004 14:03:33
 Re: Front Jack Point on 135 - Oil Pan? in reply to DavidP,South Wales, 12-23-2004 11:18:23
Thanks a lot for this information!
I guess there is no liklihood of the tractor tipping forward on the support from the position you describe..?... I have the back wheels and fender/supports off for painting.....
I guess it will be obvious if I take it easy.
bd
DavidP, South Wales
12-25-2004 11:24:59
 Re: Front Jack Point on 135 - Oil Pan? in reply to Bill Darte, 12-23-2004 14:03:33
Hi,
No, no chance.
DavidP
