massey ferguson 135 serial # location
Mike Ray
12-24-2004 04:12:27
trying to locate serial # on MF 135 diesel probably 1965-67 year..lots of stamped part numbers but can't locate serial # ..where is it located? Thanks
Tim A.
12-24-2004 11:41:58
 Re: massey ferguson 135 serial # location in reply to Mike Ray, 12-24-2004 04:12:27
Hi and if this may be of help; Look below and to the right hand side of the battery tray. (sitting in the drivers seat).There should be a plate below the battery tray forward of the steering box and directly behind the engine, near the top. The early 135 American versions had it on a plate there. The later ones had it on the dash beow the key switch. The later ones usually started with a 9a and series of numbers. The early ones had eg. "SDM"in front of a number. Try this and good luck!
Gerald J.
12-25-2004 12:11:46
 Re: massey ferguson 135 serial # location in reply to Tim A., 12-24-2004 11:41:58
The serial number list I saw didn't say SDM for the starts on any 135. I think that applied to the 35 and previous. My list starts with early trctors (as extracted from the factory parts book) having the 9A (as my '68 has) prefix, then by about 1970 that prefix was taken off. There should be a breakdown by year on this web page somewhere though I've not checked it for accurace. I'm hundreds of miles from my manuals so I can't check for closer details.
Gerald J.
Tim A.
12-26-2004 06:28:59
 Re: massey ferguson 135 serial # location in reply to Gerald J., 12-25-2004 12:11:46
Hi again, Sorry about the SDM designation mix up.
We have to be carefull and remember that the 135 tractors were made in two versions; The American and UK version. It may be interesting to have a discussion on the differences so that all will know that not all 135's are the same or use the smae serial number set up! I own a 135 UK.
Gerald J.
12-26-2004 09:43:39
 Re: massey ferguson 135 serial # location in reply to Tim A., 12-26-2004 06:28:59
My US parts book, shows only serial numbers beginning with 9A or with all numbers. Since I live in Iowa, I don't see UK MF-135 much. I can't speak for the UK and far east versions.
Gerald J.
masseyman50
12-25-2004 06:47:58
The plate for a UK modle was right on the dash. Thats if its still there.
Gerald J.
12-24-2004 04:18:17
On my '68 MF-135 the tractor serial number is on a tag below the steering column. On that lower dash panel. The engine has a separate serial number tag. All those part numbers ending in M1 are part numbers, not serial numbers. Your serial number will start with a couple letters but I've forgotten what they are. They changed to all numbers about 1970.
Gerald J.
