MF 35x
16535
12-27-2004 06:03:00
Has the MF 35x 1965 got a live or independent P.T.O?
ben uk
12-27-2004 08:44:19
 Re: MF 35x in reply to 16535, 12-27-2004 06:03:00
It has live PTO on a dual stage clutch.
You havent got a 1965 25X though - stopped prosuction end of 64 as far as i know.
ben uk
12-27-2004 08:45:05
 Re: MF 35x in reply to ben uk, 12-27-2004 08:44:19
in my last post i meant 35x, sorry, ought to learn to type one of these days!
sibby(Aus)
12-27-2004 13:33:57
 Re: Ben u.k. in reply to ben uk, 12-27-2004 08:45:05
Ben, how did you get on with your loader on your 135?
ben uk
12-27-2004 13:46:54
 Re: Ben u.k. in reply to sibby(Aus), 12-27-2004 13:33:57
Hi sibby, thanks for asking!
Its not on yet, im just waiting for the mechanics next door to weld up a frame to go uner the front and we should be away.
The belly plate (as i call it!) is on, the hydraulics are sorted, just needs the front support welding up.
Thanks
Ben
lonestarjeff
12-30-2004 21:05:11
 Re: Ben u.k. in reply to ben uk, 12-27-2004 13:46:54
Ben:
What loader are you mounting? Did you use a MF valve on the lift cover or remote? Front pump or going off the internal pump?
Jeff
ben uk
12-31-2004 04:39:05
 Re: Ben u.k. in reply to lonestarjeff, 12-30-2004 21:05:11
hi jeff.
It is an MF40 loader, with an aftermarket valve on the lift cover, using the internal hydraulics. The one thing i will say about that valve is that it was a bar***rd to get a spanner on!
I just about managed to get it tight with an old socket that had a nice thin lining, so would just about grip the tope of the bolt to pull it down.
thanks for taking an interest
