Installing tractor toe chains
Brian Horton
12-30-2004 16:02:06
What's the trick for installing the chains. I just bought a new pair of chains (H pattern) for my Massey Ferguson 135 . Tire size is 14.9-24.
It seems impssible to get the chains tigth enough to stay centred on the tire.
Ken in Iowa
12-30-2004 20:26:25
 Re: Installing tractor toe chains in reply to Brian Horton, 12-30-2004 16:02:06
I have been putting tractor tire chains on for about 60 years and I will point out that tractor chains will grip well and cause less tire damage if they are run a little loose. As long as they are tight enough to stay on, just keep your speed down and run them. Good Luck, Ken
GaryF
12-30-2004 17:47:54
Brian.. It sounds to me that your chains are to long however before you start cutting them you should try a search of entire site using "tire chains" as search parameter there should be tons of info on this subject.
Good luck
Gary
Johan
12-31-2004 05:35:33
 Re: Installing tractor toe chains in reply to GaryF, 12-30-2004 17:47:54
Once you have have them on and drive around a bit and tighten them again. Make sure that you have the outer chains (on the sides) thigh enough, I suppose you have locks for that (see page 3 on the broshure (right-hand side, second to last row, prices in Euros) ("TR-ketjun lukot"). That makes it easy to tighten and connect.
