101 JR -wiring
E.C.
04-14-2000 03:59:54
I let a friend borrow my 101 JR to pull out a few logs and told him the battery was weak,so if he had to jump it to remember it was a positive ground.Well,guess what?My wires are now non-existent.He fried them all.I don't know what damage was done to any other part in the electrical system.This is a 12 volt system.Any advice?Since so much was burned up,should I rewire the same way it was,or change it.And does anyone have a complete wiring diagram?Thanks.
Alberta Mike
04-15-2000 05:51:56
 Re: 101 JR -wiring in reply to E.C., 04-14-2000 03:59:54
I've got an original wiring diagram for a 101 Junior, however since yours has been rewired for 12 volt, you never know how close to original it is. For example, you probably are not using the 3 position light/charge rate control switch on the dash (since you're likely running an alternator). If you're interested, let me know by email, I'm not always in touch with the YT forum. I could scan this one here and send it to you by email. My address is:
mballash@wci.ab.ca
I've got 2 101's, what year is yours? Where abouts do you live?
Mike
