MF399
CBBC
01-13-2005 18:27:13
I'm looking at a couple of 399's. Both have loaders and are FWD. About 3500 hrs on one and 5500 on the other. Anything special I should watch out for? What are they worth app?
Thanks, Grant
Toolbox
01-14-2005 11:23:30
 Re: MF399 in reply to CBBC, 01-13-2005 18:27:13
CBBC,
Check over the front axel for worn parts, U/Js, Swivel bearings especially the bottom ones and the track rod ends. Also check the 4wd for engagement and disengagement.
The clutch is another thing to look at especially if its on a loader, and also make sure the steering isn’t heavy as some 300s suffered from hydraulic pump problems I think it was the sun strand pumps that didn’t last long which was replaced in service with a bosh pump
What engines have they got is it the Perkins 6.354 or the 1006 series the later being a cracking power unit. Also what gearboxes have they got, if it’s a 12x12 manual shuttle then check the fwds. and Rev is ok and the Hi Medium & Low ranges all work ok.
But on the whole a very reliable tractor that always makes good money.
