135 Pivot Pin Removal/Replace
Bill Darte
01-17-2005 07:48:14
Hi,
I'm about to remove the front axle of my 135. I will pull the pivot pin and am wondering about its replacement. Do I simply hammer it home using a wood block as a cushion after painting with a little anit-seize?
What's your advice...and thanks.
Bill Darte
supergrumpy
01-17-2005 08:37:05
 Re: 135 Pivot Pin Removal/Replace in reply to Bill Darte, 01-17-2005 07:48:14
make sure you get the right replacement pin, one version is shorter and has an oblong welded-on ear up front, mine was longer straight pin with keeper bolted into a locking notch in pin, order 2 bushings, factory only puts rear one in
my OEM pin was solid with tapped hole in front, replacement pin was hollow and slipped right into place with good coat of anti-seize, hollow pin allows front hydralic pump to be added
my pin was really set up in there and coat of factory paint made it even tighter, after much bad language and help from Big Dean, I pulled radiator off to get room to work
soak pin well with favorite penetrating oil, PB Blaster worked for me, 10 lb sledge finally got pin moved 1/32" back, then I unbolted front end and worked on unit off the tractor, once it moves that little bit, you are on the home stretch
maybe yours will slip right out
Bill Darte
01-17-2005 17:15:29
 Re: 135 Pivot Pin Removal/Replace in reply to supergrumpy, 01-17-2005 08:37:05
Right.... good advice there, but actually I'm not too concerned about getting it out....
What I would like to know is about getting it back into place.
Wood block and a sledge?
Do I need to heat the cast front end before reassembly? Freeze the pin? Both?
Thanks.
bd
supergrumpy
01-18-2005 09:15:38
 Re: 135 Pivot Pin Removal/Replace in reply to Bill Darte, 01-17-2005 17:15:29
I put anti-seize on the new one and it slid in real nice by hand, this is on 1970 MF135 perkins with swept-back axle
the bushings are pretty sturdy so I beat mine into place, used permanent loctite on them so I"m hoping they stay in place
if your pin goes in hard, I would make sure everything is in right, check in the bore for a rough edge and grind any off you might find, then wail away with the 5lb sledge
this is not precision work
Bill Darte
01-18-2005 10:20:02
 Re: 135 Pivot Pin Removal/Replace in reply to supergrumpy, 01-18-2005 09:15:38
Thanks again...
One more thing... you say yours is a 1970 MF135.
So is mine.. with serial # 9A 106280. Do you happen to have your serial #.... just curious.
Mine is a 3 cyl. gas. If yours is, I would really appreciate knowing what the Engine Serial # is.
Again, mine is 152UA11927A.
The reason I ask is I am trying to determine whether the engine is original to the tractor.
Thanks...
Bill Darte
314 935-7575
supergrumpy
01-18-2005 15:05:59
 Re: 135 Pivot Pin Removal/Replace in reply to Bill Darte, 01-18-2005 10:20:02
mine is gas
tractor is way out in the filthy wilds of upstate NY right now @ 2 degrees and dropping, nice and warm right here inside
will try and remember to get it for you next time I venture out there
