MF breakers in Ireland MF148 power steering parts
bg148
02-06-2005 15:12:17
Any body have details of MF breakers in Ireland? I am looking for some pipe work for the power steering on my 148. Specifically the pipe that goes on the bottom left of the power steering control valve on the steering column. The bolt has been over tightened and compressed the knuckle and it will not seal properly. Replacing the complete pipe if I can get one may be less hassle then trying to get the old one repaired.
Cheers
bg
DavidP,South Wales
02-07-2005 13:45:29
 Re: MF breakers in Ireland MF148 power steering pa in reply to bg148, 02-06-2005 15:12:17
Hi bg,
You may be able to find one at a breakers but you have the same problem with a S/H pipe It is possible to have one made but due to the complex shape it would be better to fit a new one.
The following numbers should be good:-
The Upper pipe should be 1860-247 M91
The Lower pipe should be 1860-249 M91
Sealing Rings are 891-785 M1 (inner)
and 828-498 M1 (outer).
Good luck
David P
bg148
02-07-2005 14:29:32
 Re: MF breakers in Ireland MF148 power steering pa in reply to DavidP,South Wales, 02-07-2005 13:45:29
David,
Thanks for the info. Strange as it may seem I had not considered trying to get original parts from Massey, I have found in the past on a number of occasions when looking for bits, that I was just fobbed off with the line that its an old tractor and OEM parts were not available. I have a breaker here locally who has a good stock of old Massey bits and pieces and in the past has always managed to sort me out with parts but unfortunately not in this instance.
Maybe I should try a different dealer; you reckon Massey should still be able to supply the parts?
Cheers
Brendan
sam neill
02-20-2005 16:52:54
 Re: MF breakers in Ireland MF148 power steering pa in reply to bg148, 02-07-2005 14:29:32
which part of ireland are you in? give me a bell on o44 2838 849954 imay be able to help
sam neill
02-20-2005 16:52:46
