MF Sickle Mower ID ?
Charlie in MO
02-12-2005 12:11:05
Today I found a 7' MF sickle bar mower and the only ID on it was the Ser. 238 0498899. Is there a way I can gather model information on this mower? Anyone know if I could use it on a 2N Ford? Thanks.
thebigron
02-12-2005 18:16:13
 Re: MF Sickle Mower ID ? in reply to Charlie in MO, 02-12-2005 12:11:05
Is it a rear or side mounted. Have a pitman (wooden arm) or look like a crankshaft inside the drive housing. Is it cast iron body or steel fabricated. If you can post a decent picture on this site I'm sure me or someone can identify. I cannot find any listing of serial numbers for these mowers. Maybe someone has such a list, would love to have a copy.
Charlie in MO
02-12-2005 19:23:52
 Re: MF Sickle Mower ID ? in reply to thebigron, 02-12-2005 18:16:13
The guy wants 165.00 for the mower? Think thats too high? He already told me the bearings are out of it. If this sounds like a reasonable deal, I'll get some photos of it and let you have a look. Might be a nice accessory, although a project, I'm sure. Also an area I know nothing about. Some kind of manual would sure help.
Thanks for you help with this.
Charlie in MO
02-12-2005 19:28:59
 Re: MF Sickle Mower ID ? in reply to Charlie in MO, 02-12-2005 19:23:52
Sorry, it is a rear mount. Looks like cast. The mower frame at the 3 pt hookup has a short arm under the left 3pt arm that looks like it assist in raising the mower arm.
thebigron
02-13-2005 14:46:46
 Re: MF Sickle Mower ID ? in reply to Charlie in MO, 02-12-2005 19:28:59
Assuming you do not have a pitman stick/rod ; It would probably be a 30 or 31; both of these have a cast iron body. It would not be the 41 as it is a fabricated steel body. Still need a photo to make sure. The 31 would look from a distance like two horseshoes upside down as a frame. The 30 would have (if still intact) a guard on the larger pulley (left side of tractor).
2x4
02-12-2005 20:28:26
prob. a MF 31 or MF 41
