need to do a little scraping
Alan Steadman
02-13-2005 20:12:34
The model & serial # is stamped INTO the top of the tranny cast next to your left ankle. The #'s you have supplied are casting #'s and don't tell much. They are usually very faint and a second coat of paint with some grease over it hides it completely. Good luck - Alan
DANZ
02-14-2005 19:24:20
 Re: need to do a little scraping in reply to Alan Steadman, 02-13-2005 20:12:34
DID SOME SCRAPING AND FOUND ON TOP OF THE TRANSMISSION STAMPED #"S 1244GISF AND UNDER THIS WAS THE # 3096. ARE THESE THE CORRECT #"S TO HELP IDENTIFY. THANKS
Bruce C
02-15-2005 04:52:38
 Re: need to do a little scraping in reply to DANZ, 02-14-2005 19:24:20
From the numbers you posted you have a 1956 Air Force model.The I244 is the engine size.G is for gas,1 is regular altitude,S is standard axle,F is foot clutch.#3096 is the serial number.There were two models of the 244 made for the Air Force and Navy.Made from 1955 to 1957.A total of 708 were made.
